oil filter
Old Jul 26, 2007 | 01:49 PM
cmares's Avatar
cmares
Default oil filter
Last night I changed my oil. I drained out 5 quarts but there was no oil in the filter. Has anyone seen this before? What could be the reason?
Old Jul 26, 2007 | 01:58 PM
Fox Fader's Avatar
Fox Fader
Default RE: oil filter
What do you mean by no oil?
Does this mean it was dry like new, cause this is not likely.
Old Jul 26, 2007 | 04:40 PM
cdusthockey's Avatar
cdusthockey
please exaggerate, never heard of this happening, and if it really did your motors fuc#ed
Old Jul 26, 2007 | 04:43 PM
spaz_22's Avatar
spaz_22
do you mean while you were taking of your oi filter no oil drained out, and there was no oil in your oil filter? or when you were taking off your oil filter there was oil draining out of the treaded hole, but there was not an abduntent(sp?) amount of oil in the filter? if tthe first case, your oil pump is probably going bad. If the second case, it's nothing abnormal. Since the oil filter sits horizontally and not vertically.
Old Jul 26, 2007 | 06:29 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: cdusthockey
I think we would rather he elaborate, not exaggerate.
Old Jul 26, 2007 | 07:06 PM
kayakman's Avatar
kayakman
Gotta ask this question. Was it a Fram filter?????[sm=badidea.gif]
Old Jul 26, 2007 | 07:50 PM
OlsenG_360's Avatar
OlsenG_360
where i work i've seen this 3 times in the last 2 years, (all fram filters btw)every time it meant a new engine.1 of the times when i pulled the drain plug...all that came out was SMOKE, not a drop of oil in the engine []
edit: i'm not saying the filter was the problem every time, just an observation. but please people, use a decent oil filter.
Old Jul 26, 2007 | 08:55 PM
padodgeram's Avatar
padodgeram
that 1 time you pulled the drain plug and all came out was smoke ...this the filter fault ? or the person that dont check the oil...at that point doesnt matter what oil filter is on if there is no oil to filter..
Old Jul 26, 2007 | 09:01 PM
Cereal Killer's Avatar
Cereal Killer
That sounds more like someone had a ****ing hole in their oil pan or something crazy.
Anyways if you run your finger along the inside of the filter and it's bone dry you're gonna have a bad time. Check your pan and the plug and the seals and the pump. what does your oil pressure guage read when the truck is on?
Old Jul 26, 2007 | 09:50 PM
OlsenG_360's Avatar
OlsenG_360
the 1 time i pulled the plug & got smoke, it was owner negligence. they hadn't had the oil changed in almost 42,000 milesand probably never checkedthe level in that time either[:-]...the guy thought he'd be nice and change the oil before he sold the car ...i feel really bad for whoever bought that car...1987'ish Ford Escort
funny thing is...when it came into the shop it was clanging and making all kinds of engine noise...when it left it sounded smooth as a new car.
