HELP!!!!! Fuel inj problems????? black smoke?
Old Jul 29, 2007 | 03:01 PM
mopowar's Avatar
mopowar
Default RE: HELP!!!!! Fuel inj problems????? black smoke?
What Tani said- check your injectors. Get a stethascope or piece of hose and listento them with the truck running. They should have a noticeable click to them. It could also beyour map sensor. You will need a dvm or scanner to check that. A vacuum leak will lean you out and would only help if you have over feuling issues.If you have been running rich for a while, and have the factory cat it is either fried or close to it.
Old Jul 29, 2007 | 03:10 PM
OlsenG_360's Avatar
OlsenG_360
timing could also be off a ways, another thing to check out
