Oil pressure delay
Old Jul 29, 2007 | 01:53 PM
FFFD827's Avatar
FFFD827
Default Oil pressure delay
When i start my truck my oil pressure guage stays down for about 2-3 seconds before riseing. Is this a problem for any of you or is it just a delay in the guage?
Old Jul 31, 2007 | 01:15 PM
Redneck2345's Avatar
Redneck2345
Default RE: Oil pressure delay
its gonna take a couple seconds for oil to be pumped up to the heads, mine does the same
Old Jul 31, 2007 | 01:23 PM
BLKbeast's Avatar
BLKbeast
pump might be getting clogged...
mine hits almost 60 when i start it up then slowly drops to 40.
Old Jul 31, 2007 | 01:29 PM
rtmorrisjr's Avatar
rtmorrisjr
mine does it also. the pump has to push the oil from the pan, to the top of the motor, before it will get a reading. its cause the sending unit is on top of the block
Old Jul 31, 2007 | 04:13 PM
defiantmopar's Avatar
defiantmopar
I have the same issue with mine but it is intermitent. Some days its right away and others it the check guage light comes on for a breif second.
Old Jul 31, 2007 | 06:31 PM
dishdude2k's Avatar
dishdude2k
if it aint broke.. dont fix it.. there isnt anythng wrong with the delay.. 1.. takes a second or 2 to get the oil to the top of the motor.. 2. its all computer controlled.. ya gotta let it go thru its 'boot up' process
Old Jul 31, 2007 | 09:27 PM
dhvaughan's Avatar
dhvaughan
its normal. mine takes about 2 seconds to register also. since pump is mechanical it has to pump the oil column all the way to the top of the motor.
