whats next?
Old Jul 29, 2007 | 09:43 PM
milkdud110's Avatar
milkdud110
Default whats next?
i have a 2001 ram 1500 sport 318 5.2 liter i have a little extra money to spend on parts what should i get next? i am asking you guys because i have no idea
what i have now
dual exhaust
hypertech III programmer
180deg stat
velcity cold air intake
WHT DO YOU GUYS THINK I SHOULD DO?
Old Jul 29, 2007 | 10:10 PM
milkdud110's Avatar
milkdud110
Default RE: whats next?
one more thing how do i know what size my rear end is?
Old Jul 29, 2007 | 10:15 PM
spaz_22's Avatar
spaz_22
50 mm fastman throttle body $229. Your rear axle should be a chrysler 9.25 from the factory. Look on the underside of the hood, or in the glovebox or get a build sheet from the dealership, but if your truck is stock it is a 9.25. you should also say how much you have to spend, but my recommendation is the 50 mm tb from fastman
Old Jul 29, 2007 | 10:20 PM
milkdud110's Avatar
milkdud110
about $300 i looked in the glove box it dont say and i looked on the rear end it has 1990 and 3.5 on little metal tags
Old Jul 29, 2007 | 10:25 PM
cvec7's Avatar
cvec7
You might also want to consider a set of roller rockers. Some have seen pretty significant gains in the low-mid rpm ranges. So theoretically, it should help out your fuel mileage when just cruising around since you won't have to use as much throttle to get up to speed. If I wasn't selling my ram in a year, I'd pick up a set myself.
Old Jul 29, 2007 | 10:43 PM
Fox Fader's Avatar
Fox Fader
Do this and the Hypertch
Old Jul 29, 2007 | 10:45 PM
milkdud110's Avatar
milkdud110
what size roller rockers should i look for? i found 1.7 full roller, 3/8 stud self alinging but they r like 800 bucks a little to much for now i think
Old Jul 29, 2007 | 10:47 PM
milkdud110's Avatar
milkdud110
ORIGINAL: Fox Fader
were did you get that stuff? i like
Old Jul 29, 2007 | 10:49 PM
milkdud110's Avatar
milkdud110
how hard is it to install Underdrive Crankshaft Pulley
Old Jul 29, 2007 | 11:06 PM
cvec7's Avatar
cvec7
ORIGINAL: milkdud110
I'm not sure on what size you need, but some searching should be able to tell you. $800? When I was looking into it, a set of Harland Sharps were around $300....
