ok 4x4 guys need some info
Old Aug 5, 2007 | 12:25 AM
ryans590's Avatar
ryans590
Default RE: ok 4x4 guys need some info
ORIGINAL: Silver_Dodge
Ok, here you go. My lift is Skyjacker 3" (D301K), which is basically 3" coils in the front, and an AAL for the rear. I arecently added Skyjacker control arms designed for 3" of lift, but they didn't originally come with my kit.
-Not sure what you were calling the bottom of the bumper, the bottom of the gray part, or the bottom of the black piece?
-Ground to wheel well in front: 41 1/8"
-Ground to wheel well in back: 43 1/4"
My rear block is the stock block, and I am sitting on 285/70/17's at the moment. These measurements are from the passenger side too, which sits a little higher then the driver side. Seems to be common on the 2nd gen Rams.
Have you considered a body lift on top of your 3" suspension lift? You could do 2" or 3", and run 35's, maybe even 37's. That's what i'm about to do.
finally somone my numbers make sence compaired to i was begining to think in got the mini virson of a ram lol
Old Aug 5, 2007 | 10:15 AM
padodgeram's Avatar
padodgeram
Well im thinking of doing a 3" body in october but gotta be carful with pa height laws ,30" from ground to bottom of bumper (grey part).. but 3" lift 3 " body mite be high enough.... and i did some measurements 34 tire would fit now , so your 35 or 37 is in the picture with the body lift....
Old Aug 5, 2007 | 11:24 AM
AAA4948's Avatar
AAA4948
LF: 37.25"
RF: 37.75"
LR: 40.25"
RR: 40.75"
Stock suspension with 265/75R16 Cooper Discover ST's with 11/32 of tread. Interesting that the right side is higher. Steering column and fuel tank?
Old Aug 5, 2007 | 01:31 PM
ryans590's Avatar
ryans590
ORIGINAL: padodgeram
if you have a 3 in suspention lift youll get 35's in there now
Old Aug 5, 2007 | 02:27 PM
Silver_Dodge's Avatar
Silver_Dodge
Depends on the backspacing on your rims though.
Old Aug 5, 2007 | 02:59 PM
ryans590's Avatar
ryans590
yah i havw my stock rims still and they rub a little on the control arms at full turnbut not too bad, when i get ritch again im gonna get new rims
