Seatbelt issues
Old Aug 1, 2007 | 03:41 PM
Kershaw76's Avatar
Kershaw76
Default Seatbelt issues
I just bought a 98 ram 1500 2wd 5.9 last week. There's alot of stuff that needs fix but this problem just started today. Both front seatbelts don't release. I've try everything to get them to release a couple hours later they started working but didn't last long (a trip around the block) while I was driving the seatbelt light came on then a clicking sound started from the driver and passenger side where the seatbelt rolls up. I now can't get them to release at alland there is no more clicking
has anyone else had this problem?
Old Aug 1, 2007 | 06:06 PM
froesen's Avatar
froesen
Default RE: Seatbelt issues
There is a seatbelt module located underneath the center seat. The clicking you are hearing are solenoids inside the seatbelt itself which when deenergized lock the seatbelt. The module recieves inputs from the airbag module and also has a rollover sensor inside of it (mine rattled so I took it apart, lol). There's also an ACC source to the module and a 12+ fed from the IOD fuse. I haven't had your particular problem, but hopefully this points you in the right direction!
Old Aug 1, 2007 | 07:07 PM
Kershaw76's Avatar
Kershaw76
thx for the reply but my problem seem to be getting bigger
my air conditioner was working great this morning but a short trip to town and now it blow hot air and my check engine came on
I was told that it might be the ecm since I'm having seatbelt and air and check engine problems
Old Aug 1, 2007 | 08:31 PM
ryans590's Avatar
ryans590
well for the seat belts check under your drivers seat there is a plug there that can wiggle loose mine did (i also store lots of crap under there) as for the CEL get the codes read unfortnatually (like me) you cant check the codes your self in 98 theydisabled the on off on thing then put it back in 99 cuz too many pepole complained but you can take it to a shop and have then check it for you
