temperature control
Old Aug 1, 2007 | 07:10 PM
bri's Avatar
bri
Default temperature control
Myheater/A/C either runs at cold or hot with no in between temperature. If the control **** isturned from full cold on the left to a moderate temp to the right, it will just blow hot air. What and where do you suppose is the source of this control failure?
Old Aug 1, 2007 | 07:23 PM
WayneC's Avatar
WayneC
Default RE: temperature control
Sounds like your blend door is sticking. It is either open or shut--no inbetween. Do you get any popping sound when changing from cold to hot? Take the glove box out and the blend door is right behind. Make sure it is working and still connected to the actuator.
WC
Old Aug 2, 2007 | 06:29 AM
bri's Avatar
bri
Thanks, Wayne. I'll check it out. Last time my A/Cstarted blowing hot air I did hear a pop.
