stats on 2500
Old Aug 3, 2007 | 05:56 PM
motorbrreath's Avatar
motorbrreath
Default stats on 2500
anyone know the specs on a (1995) 2500 4x4 with the 360? horsepower/torque is all i need to know. sorry for the newb question, just got this dodge.
Old Aug 3, 2007 | 10:23 PM
95ramdan's Avatar
95ramdan
Default RE: stats on 2500
I still have the window sticker for my 95 5.9 and it says 230hp 330ft lbs torque.
Old Aug 3, 2007 | 11:08 PM
motorbrreath
thanks ramdan, people have been kinda slow around here to respond, gotta grow out of my newbie status
Old Aug 4, 2007 | 12:07 AM
Socha_62's Avatar
Socha_62
ORIGINAL: motorbrreath
Just for future reference, don't really expect any deffinate answers in under 24 hours. It always makes me laugh when I see a thread made at say 1:43pm and at 1:54 the same person is like "DOESN:T ANYBODY KNOW? BUMP!"
Not saying you did it to that extreme but usually you can get a few different perspectives after 24 hours.
Old Aug 4, 2007 | 01:16 AM
ryans590's Avatar
ryans590
we may not get to ya right away but well get to you eventually unfrtnatually i dont sit at my computer all day long, and us 2nd gen's keep getting less in numbers while the 3rd gen grows (traders!!)
here is some info from a diffrent post, might be what your looking for
from https://dodgeforum.com/m_909741/tm.htm
wrote by
spaz_22
ENGINE: 3.9-LITER MAGNUM�, OHV, SMPI V-6
Type & Description
Six cylinders, 90� V-type, liquid cooled
Displacement
239 in3 (3906 cm3)
Bore x Stroke
3.91 x 3.31 (99.3 x 84.1)
Valve System
OHV, 12 valves, roller followers, hydraulic lifters
Fuel Injection
Sequential, multi-port, electronic
Construction
Cast iron block & heads
Compression Ratio
9.1:1
Power (SAE net)
175 bhp (131 kW) @ 4800 rpm (44.9 bhp/liter)
Torque (SAE Net)
230 lb.-ft. (312 Nom) @ 3200 rpm
Max. Engine Speed
5250 rpm
Fuel Requirement
Unleaded regular, 87 octane (R+M)/2
Oil Capacity
4 qt. (3.8 L)
Coolant Capacity
20 qt. (19 L)
Emission Controls
3-way catalytic converter, heated oxygen sensors (2), engine modifications
Estimated EPA Fuel Economy
(MPG City/Hwy)
15/21 man.; 15/20 auto.
Alternator
117 A
Battery
Maintenance-free, 600 CCA - std., 750 CCA - opt.
ENGINE: 5.2-LITER MAGNUM�, OHV, SMPI V-8
Type & Description
Eight cylinders, 90� V-type, liquid cooled
Displacement
318 in3 (5208 cm3)
Bore x Stroke
Valve System
OHV, 16 valves, roller followers, hydraulic lifters
Fuel Injection
Construction
Compression Ratio
9.1:1
Power
(SAE net)
230 bhp (172 kW) @ 4400 rpm (42.3 bhp/liter)
Torque
(SAE Net)
300 lb.-ft. (407 Nom) @ 3200 rpm
Max. Engine Speed
5250 rpm
Fuel Requirement
Oil Capacity
5 qt. (4.7 L)
Coolant Capacity
20 qt. (19 L)
Emission Controls
3-way catalytic converters, heated oxygen sensors, engine modifications*
Estimated EPA Fuel Economy (MPG City/Hwy) 1500 2WD:
13/18 man., 13/19 auto.; 1500 4WD: 13/17 man., 12/16 auto.
Alternator
117 A - std.; 136 A w/trailer tow, snow plow etc.
Battery
* With automatic transmission in CA, system meets LEV (Low Emission Vehicle) requirements.
ENGINE: 5.9-LITER MAGNUM�, OHV, SMPI V-8
Type & Description
Eight cylinders, 90� V-type, liquid cooled, light duty
Displacement
360 in3 (5895 cm3)
Bore x Stroke
4.00 x 3.58 (101.6 x 90.9)
Valve System
Fuel Injection
Construction
Compression Ratio
8.9:1
Power (SAE net)
245 bhp (183 kW) @ 4000 rpm, (39.0 bhp/liter) 250 bhp (187 kW) @ 4400 rpm (41.5 bhp/liter) w/Sport Group
Torque (SAE Net)
335 lb.-ft. (454 Nom) @ 3200 rpm, 345 lb.-ft. (468 Nom) @ 3200 rpm (w/Sport Group)
Max. Engine Speed
5250 rpm
Fuel Requirement
Unleaded regular, 87 octane R+M/2
Oil Capacity
5 qt. (4.7 L)
Coolant Capacity
20 qt. (19 L)
Emission Controls
1500 2WD: 13/17; 1500 4WD: 12/16 auto.
Alternator
Battery
Old Aug 4, 2007 | 10:04 AM
95ramdan's Avatar
95ramdan
I believe those stats are for 97+ rams. 94-96 rams had a little less power.
correct me if im wrong anyone...
