Found bolt WOOOOOOOOOOO!!!!
Old Aug 4, 2007 | 02:24 PM
2001dodgeram1500's Avatar
2001dodgeram1500
Default Found bolt WOOOOOOOOOOO!!!!
ok i found the bolt and am going to put it back together
so maybe it will run like it should
i am replacing the coolant with the green stuff and distilled water
well thanks for all suggestions and help.
Old Aug 4, 2007 | 02:47 PM
dhvaughan's Avatar
dhvaughan
Default RE: Found bolt WOOOOOOOOOOO!!!!
cool. where was it ?
put some rtv where the rubber intake gasket ends meet the head.
Old Aug 4, 2007 | 07:49 PM
2001dodgeram1500
it was stuck in the intake manifold. i could manuever the magnet a little better after i got the alternator and the AC compresser off and it sucked it right out. i had already taken the fuel injectors and lines apart and then thought might as well give the magnet 1 more try and it worked, it saved me alot of time. it's all back together and is running i used a 195 degree thermostat and i used the RTV too.
thanks for the help guys
