whining sound while turning
Old Aug 6, 2007 | 02:25 AM
ryans590's Avatar
ryans590
Default RE: whining sound while turning
ORIGINAL: timwag2001
ive never heard of that for a bearing. thats how i check my ball joints.
a lot of times you can do a visual inspection of the ujoint in the axle. you can usually see the damage on the caps.
doesnt the 2 wd have bearings and the 4 wd have ujoints?
i dident even look and see it was 2wd there wont be u joints there since there isent a front drive axle and the barring is part of the hub assy (not the u-joints) the whole assy has to be chaged if its a bad barring
that wiggle checks both if its making a noise prob not a ball joint, also you can usally see the ball joint move if thats whats bad if its not moving then most likley barring
Old Aug 6, 2007 | 06:56 AM
dishdude2k's Avatar
dishdude2k
best way to check wheel bearing/hub assy. is to lift tire off ground.. and grab left/right side of tire.. or top/bottom side of tire.. pull OUT equally.. if you can move the tire in and out.. its shot.. you should not be able to move it at all.. if you can move it up and down like was stated in post earlier.. but not in and out.. chances are its not the bearing/hub and it is a balljoint.. check those out..
Old Aug 6, 2007 | 07:15 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: Captain Squalus
I had a whining sound but I got rid of the Bitch so I don't here it anymore
good one
Old Aug 6, 2007 | 03:05 PM
ryans590's Avatar
ryans590
ORIGINAL: dishdude2k
grabing left/right will also tell you if your tye rod ends are shot, if you have big tires your gonna have a hard time trying to pull it straight out and in if you have smaller ones than this may work thow, ive never tryed pulling it straight in and out, ill try that one next time i check it thow cuz im courieous
Old Aug 6, 2007 | 03:19 PM
kingofnothing14's Avatar
kingofnothing14
alright i'll check that out, i gotta wait a couple days, i just got the "boys" cut, so I'm recovering from that... but i'll post back up here when i check it out....thanks!
