whining sound while turning
Old Aug 5, 2007 | 08:19 PM
kingofnothing14's Avatar
kingofnothing14
Default whining sound while turning
I noticed I have a warped kinda whining sound when making slow turns, more with hard right turns, top speed of about 15...it's coming from the wheel well....any ideas?
Old Aug 5, 2007 | 08:22 PM
timwag2001's Avatar
timwag2001
Default RE: whining sound while turning
hows your power steering fluid doing?
Old Aug 5, 2007 | 08:38 PM
kingofnothing14
it's good i changed it about 6 months ago...
Old Aug 5, 2007 | 08:47 PM
aim4squirrels's Avatar
aim4squirrels
Constant sound or cadenced (at regular intervals)? Does it speed up/get higher when you go faster?
I had a passenger side wheel bearing go out that I only noticed during turns to start with.
Old Aug 5, 2007 | 08:49 PM
ryans590's Avatar
ryans590
im gonna guess a wheel barring on u-joint
to check wheel barring, lift the corner of the truck up so the tire is off the ground try to wiggle it top to bottem if it wiggles its a bad barring
u-joint with the tire still in the air spin the tire (in 2wd) look at the axle u joint if there is slop in it then its bad
Old Aug 5, 2007 | 09:35 PM
timwag2001's Avatar
timwag2001
ive never heard of that for a bearing. thats how i check my ball joints.
a lot of times you can do a visual inspection of the ujoint in the axle. you can usually see the damage on the caps.
doesnt the 2 wd have bearings and the 4 wd have ujoints?
Old Aug 5, 2007 | 09:42 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: kingofnothing14
I had a whining sound but I got rid of the Bitch so I don't here it anymore
Old Aug 5, 2007 | 09:46 PM
padodgeram's Avatar
padodgeram
4wds have bearings called the hub assembley
Old Aug 5, 2007 | 09:49 PM
timwag2001's Avatar
timwag2001
with ujoints, correct?
Old Aug 5, 2007 | 10:05 PM
motorbrreath's Avatar
motorbrreath
ORIGINAL: timwag2001
yes i had the same thing happen to me, except front left tire. bearing assembly went out, but they didnt say anything about the u joint. and 5 days later its squeakin again so its goin back in. im sure this time it will be the u joint.be prepared to dish out 300 for the bearing assembly.
