problems keeping ram running
Old Aug 6, 2007 | 04:38 PM
98rammer's Avatar
98rammer
Default problems keeping ram running
i have a 1998 ram 1500 with the 5.9l that has a small problem. when i start it up it will die, the only way to keep it running is to rev it. now this doesnt happen all the time. most of the time it starts up and keeps running just fine. no engine codes... could it be a bad pcv valve?
Old Aug 6, 2007 | 05:19 PM
95ramdan's Avatar
95ramdan
Default RE: problems keeping ram running
Try resetting your PCM first, but its most likely a TPS sensor
Old Aug 6, 2007 | 06:21 PM
dhvaughan's Avatar
dhvaughan
maybe tps-thottle position sensor (on drivers side of throttle body), but i'd go with IAC - idle air controller (on back side of throttle body) first. do a search for a million posts and be sure and clean out the well where the plunger fits as its prone to sticky build up.
