another issue to add...
Old Aug 11, 2007 | 10:13 PM
Moparkid032's Avatar
Moparkid032
Default another issue to add...
well i got my tie-rods ripped apart tonight with my friend.. he wanted to hear the truck with the new headers on..so i went to start it up..well it cranked than stopped..my friend said he saw 2 sparks come from the starter area...so i told him to tap it with the mallet while i turn the key...she cranked over slowly but she started..shut her off let her sit for a couple of minutes went to start her..cranked slowly again but fired up...so i guess i am looking for a new starter now to...[:@]
Old Aug 11, 2007 | 10:43 PM
tazman6789's Avatar
tazman6789
Default RE: another issue to add...
slow crank, you may want to check how much power your battery has while ur at it, maybe dead battery or alternator
Old Aug 12, 2007 | 05:33 AM
bill022572's Avatar
bill022572
Make sure all electrical connectionsat the starter are clean and tight. Make sure the starter is tight because if I'm not mistaken the ground for the starter is through the mounting bolts. Not likely the problem but possible. Seen stranger things and free to try.
Old Aug 12, 2007 | 10:23 AM
Moparkid032
well..i was thinking that..but one time when i cranked it last night there was a real weird sound that came from the starter..like the solenoid jammed up or something..i tried again and it didnt make the noise...thats why i am under the assumption that is is the starter
Old Aug 12, 2007 | 12:03 PM
Moparkid032
lol stupid me....do you think a lose negative cable would cause this to happen..because i noticed the battery was dead today..looked at the cable and noticed i never tightened her down..so i am guessing she never got power back from the alternator since there was no good connection..am i right?
Old Aug 12, 2007 | 12:04 PM
bill022572's Avatar
bill022572
probably is the starter --- but just anidea
