Stumped the tech....
Old Aug 14, 2007 | 05:47 PM
Trashlord's Avatar
Trashlord
Default RE: Stumped the tech....
theexhaust should be (i think don't quote me on this number) about 50 degrees hotter coming out of the catthen it was going into it...havethem check the temp on it
Old Aug 15, 2007 | 09:55 PM
rango726's Avatar
rango726
my truck goes through bouts of running good and then running terrible sometimes i can barely pull a hill with a little jon boat and trailer maybe 500lbs total. other times no prob. there are times i put my atv in the bed and i can barely keep the truck going 65 and if i pull my enclosed trailer 6x12 about 1300lbs empty forget about it its like towing 30k lbs and if i use my ac im lucky if my truck can drive itself on a level surface nevermind a hill so im really interested to hear what you find because no one can find my problem im soo fed up with the truck ive been looking to trade it in
Old Aug 15, 2007 | 11:31 PM
spaz_22's Avatar
spaz_22
my guess is your last motor burning all that oil clogged the cat, since it doesn't sound like they replaced it before. Secondly it could be that you have 33s with stock 3.55 gearing.....
Old Aug 15, 2007 | 11:43 PM
rhaines00ram's Avatar
rhaines00ram
33"s with 355 gears is going to bog you down .
Old Aug 16, 2007 | 09:34 AM
rtmorrisjr's Avatar
rtmorrisjr
Check that cat. Now that i know you had problems with the motor and getting blow by, i say its most likely the cat. if you get blow by, you are pushing oil past the rings (which you already knew) but you are also sending it into the exhaust system. And considering our cats are notorious for failing, i would almost bet money on it that its the cat. Plus, like a few other mentioned, you have 3.55's with 33's. 3.55's arnt the best lowend gears, i would say they are better for highway running.
Old Aug 16, 2007 | 09:48 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
If the cat is bad, follow up with either cleaning or replacing the O2 sensor. Otherwise, the bad O2 sensor will affect readings by the PCM, causing it to run more rich, polluting the cat, and you're back to square one.
Old Aug 16, 2007 | 10:57 AM
Socha_62's Avatar
Socha_62
ORIGINAL: big_Gymnast
Unfortunatly Socha, I don't have the truck, and probably wont for a while according to my tech, otherwise I'd go try it. According to him Chrysler tech support is EXTREMLY slow. However, I tend to hear things that are different sounding (and subsequently locate and fix the problem)and I've never heard rattling. On another note, has your truck always been sluggish, because mine has always beensince i've owned it. I'm just curious because I know a guy who has a stock 318 with 35's and a 3 inch lift and when he stomps on it he can smoke 'em for all their worth. Does you think the manufacture location makes a difference. My truck was made in St. Louis, his was made in Mexico...idk, this whole issue has gone on way too long and I just want my truck fixed....
My truck has been slow since I got it. Funny thing is when I replaced the cat (it colapsed) I hardly noticed a difference. I tried quite a few things after I first got it and now I more of less just gave up. I don't tow much so it doesn't bother me to much. I'm starting to wonder if my cylinders are worn abover average from use with crappy oil or something. I haven't done a compression test, maybe I should.
Old Aug 16, 2007 | 12:27 PM
1500sport's Avatar
1500sport
Yes I would agree that 33's with 3.55 gears and a 318 is going to be sluggish. I have a 360, 3.55 gearswhich I ran 33's on and hated it due to performance loss, and that was without towing anything. Currently have 32's and steal can't roast the tires. I assume your buddy who can smoke the 35's has some serious gears in his truck, probably 4.56s or he is one lucky guy. Of course I may have a sluggish 360 myself.
Old Aug 16, 2007 | 02:02 PM
My1995BRT's Avatar
My1995BRT
Why not take it to a dyno shop and get a couple of pulls to indicate gernated HP and Torque. Let them max it up.
Dave
Old Aug 16, 2007 | 02:08 PM
DieselDemon's Avatar
DieselDemon
ORIGINAL: rhaines00ram
Exactly. I would suspect some tranny slip too. (lockup clutch or manual)
