trans bands adjustment
Old Aug 14, 2007 | 07:17 PM
bill022572's Avatar
bill022572
Default trans bands adjustment
What size is the adjuster for the rear band on a 46re tranmission ? What do you use ?
Old Aug 14, 2007 | 10:34 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: trans bands adjustment
Are you asking about the Torx socket? I believe it's a #25. Make sure you have an INCH/lbs torque wrench to do the adjustment, NOT ft/lbs.
Old Aug 14, 2007 | 11:34 PM
bill022572's Avatar
bill022572
No - it's the rear band : looks like a square drive. Inside the pan.
Old Aug 14, 2007 | 11:46 PM
ryans590's Avatar
ryans590
5/16 and yes its "square" or 8 point
see https://dodgeforum.com/m_850060/tm.htm for more info
Old Aug 15, 2007 | 06:18 PM
bill022572's Avatar
bill022572
Thanks - I will check at sears or napa . Or maybe my snap-on dealer the next time I see him. I appreciate the info.
Old Aug 16, 2007 | 09:45 PM
PILOTGUY's Avatar
PILOTGUY
Glad to see this info. i have never changed the fluid and filter on an AT, but I wanted to adjust the bands as well.
Old Aug 16, 2007 | 09:58 PM
ryans590's Avatar
ryans590
ORIGINAL: PILOTGUY
if you have never done one before have a look at this too
https://dodgeforum.com/m_901049/tm.htm
