I just purchased a Fastman, I currently have my PCM programed with a Hypertech. Since I'll need to reset the computer, do I need to set the PCM back to stock, run it for a hundred miles, then re-program?
With my Superchips I have just been resetting the PCM with the the program still on. If your worried about it then I'd return it to stock, reset the PCM and then reprogram the PCM right away. Your PCM will have to learn it's current configuration which includes the programming so if you wait it'll take that much longer for the PCM to learn everything.
