TSB 21-08-99
Old Aug 16, 2007 | 07:55 AM
alcedo's Avatar
alcedo
Default TSB 21-08-99
Had dealer complete this TSB. Completely eliminated the awful moaning in reverse. We'll see how it does as the weather gets cooler this fall.
Cost was 180.00.
Old Aug 16, 2007 | 08:49 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: TSB 21-08-99
What was changed? My '97 does this from time to time.
Old Aug 16, 2007 | 08:57 AM
Bigdodge98's Avatar
Bigdodge98
yeah i get a slight wine too from time to time in reverse on my 98 see if u can find out what he did thanx
Old Aug 16, 2007 | 09:21 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
I found this on the Dodge TSB page.
Here is a brief overview:
Date: April 30, 1999 Models: 1996 - 1999 (BR/BE) Ram Truck 1996 - 1999 (AB) Ram Van
1996 - 1999 (AN) Dakota
1998 - 1999 (DN) Durango
1996 - 1999 (TJ) Wrangler
1996 - 1999 (XJ) Cherokee
1996 - 1998 (ZJ) Grand Cherokee
1999 (WJ) Grand Cherokee NOTE: THIS INFORMATION APPLIES TO VEHICLES EQUIPPED WITH A RE OR RH AUTOMATIC TRANSMISSION. Overview: This bulletin involves replacing the transmission regulator valve. Symptoms: Some vehicles may exhibit an intermittent noise from the transmission when reverse gear is selected. This noise has been described as a "buzz", whining", or "moaning" like noise. The noise is most noticeable when transmission fluid temperature is below 38° C. (100° F.). The condition is caused by a resonance of the transmission regulator valve system. Other items may cause regulator valve resonance, including air ingestion into the valve body or out of specification parts. These two items may be the result a possible cracked pump housing, a torn pump gasket, an under filled transmission, a restricted fluid filter or cooler flow, or an out of specification valve and/or valve body. You should remember these additional items / components when you perform your diagnosis. Vehicles built prior to August 1, 1995 may experience this condition if either a transmission valve body or an entire automatic transmission was replaced with components manufactured after August 1, 1995.
Old Aug 17, 2007 | 09:04 AM
alcedo's Avatar
alcedo
Yes, that is the TSB. I had three quotes from 3 dealers in town, One wanted 518.00 ! another 350.00 and the last 180.00. Acording to the TSB it is @ a hour to do. I was there from 11:30 - 4:00. Who knows what they were really doing. Seems to have fixed the noise though.
Old Aug 17, 2007 | 09:12 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: alcedo
That's why I work on my own stuff. It's fun, I learn something, and I know that the jerk who is working on it isn't going to rip me off
Old Aug 17, 2007 | 01:10 PM
rabbler's Avatar
rabbler
This repair does work. It's a pretty easy install. The trans valve body has to be removed but not completely disassembled. I did it to my own truck years ago. they changed the design of the valve from a light weight alloy to a heavier cast iron valve. The price of the valve was ridiculously high years ago ($350) considering it just a round piece of machined metal.
