ughh Ring gear
Old Aug 17, 2007 | 08:52 PM
Socha_62's Avatar
Socha_62
Default RE: ughh Ring gear
Good call nhlbill, I assumed this was done. If not thats the problem, but if they are out its wierd it won't slide out.
Old Aug 17, 2007 | 11:14 PM
Moparkid032's Avatar
Moparkid032
yes all that was done..hubs are off..calipers are off and axles are off.. and i pulled the caps off and marked them so i know which way they go..the assembly slides( probaly cause of no Capsbut it wont come out....i guess i just need to put some more pressure on it...now how hard is it goin to be to get back in?
Old Aug 18, 2007 | 11:16 PM
nhlbill's Avatar
nhlbill
It won't be hard to put back in at all.
Just put the carrier in place in the housing with both bearing cups on and then tap the shims into place. They will have some resistance to going in, but if you install the entire shim pack as one unit, you can tap them into the space between the bearing cup and the housing fairly easily. They should be tighter than you can push in with your fingers, but should tap in easily.
Hope you get it fixed soon, good luck.
Old Aug 19, 2007 | 01:32 AM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: Moparkid032
Thats where you need the case strecher to get the shims back in
Old Aug 19, 2007 | 02:12 PM
Moparkid032
lol well i figured out why i couldnt get it out...i didnt know there was a intermeidate shaft on the passenger side after i pulled that out it fell right out
