lowering a 3500 ram
Old Jan 5, 2008 | 01:00 AM
  #21
MeltonMotorsports's Avatar
MeltonMotorsports
Default RE: lowering a 3500 ram
The way to go is air bags and if done correctly will be just as strong if not stronger than stock. Depending on how low you go obviously you will loose some suspension travel but thats where the "adjustable" part comes in. Semi trucks and buses have Air Ride suspensions to compensate for load and improve ride. And since its adjustable on the fly, if you come up on speed bumps you just flip a switch and raise it. So you can still retain function. There were many bagged duallys at SEMA this year that not only were on display but hauled other show cars to the show. The only place you would lose function is with large diameter wheel upgrades because of the low load rated low profile tires. Anything under a 45 series tire is pretty much useless.
You can still lower a 2500 or 3500 dually on a budget with a static drop by doing front springs and rear flip kit or rear shackles, new shocks, bumpstops, and shims. When combined with a Firestone Ride Rite or something similar, you can retain towing capacity but there will be a small to moderate sacrifice in ride quality. Plus you can't adjust it for high speed bumps. Auto Parts Warehouse dot com has good prices on lowering kits for 3/4 ton and 1 ton trucks.
Old Jan 5, 2008 | 01:13 AM
  #22
motorbrreath's Avatar
motorbrreath
i think this thread is pretty much dead... aint heard anything about it in months
Old Jan 5, 2008 | 02:47 AM
  #23
SilverRam_01's Avatar
SilverRam_01
ORIGINAL: motorbrreath
WELL. I could thread-jack it. I just did. Now, what would be the oakiest/cheapest way to throw a 2/4 drop on my TWO WHEEL DRIVE RCSB pickup, so i can stuff a cam in it, throw some headers and glasspacks on it with some 17" Torque Thrusts, and then swap a 5 speed into it?? Nukka got swooped.
Old Jan 5, 2008 | 03:37 AM
  #24
92GreenYJ's Avatar
92GreenYJ
i may as well add a hijack. Has anyone seen or know of a good FULL air bag kit for a 98 1500 2wd quad cab? I want to keep the tow capacity and strength but i would love to put a full air bag system on it so i can drop it when commuting to improve gas mileage. And since its 2wd i have no guilt at all in lowering it
