Low Beams
Old Aug 18, 2007 | 11:44 PM
Robert_M's Avatar
Robert_M
Default Low Beams
My friend has a problem with his headlights. His low beams don't work but his fog lights are on. He is able to turn his high beams on but they won't stay on.
Does anyone know what the problem may be?
Thanks.
Old Aug 19, 2007 | 12:26 AM
mopar98's Avatar
mopar98
Default RE: Low Beams
Not sure, but I'm thinkin relay or the switch.
Old Aug 19, 2007 | 12:50 AM
ICEMAN_CH's Avatar
ICEMAN_CH
I had the same issue. It was the switch in my case but you should check the relay to.
Old Aug 20, 2007 | 10:33 AM
RamManRiley's Avatar
RamManRiley
Multi function switch. It controls your wipers and turn signals as well as your lights. I had the same problem i would go to flash my brights at night and it was hit or miss if the low beams would come back on or not. 60$ later problem was fixed. It is a fairly comon problem with these trucks.
