before you say NO...
Old Aug 19, 2007 | 03:33 PM
2500 mopar's Avatar
2500 mopar
Default before you say NO...
i was searching on summitracing.com and came across a throttle body spacer, HOLD ON, this is not like the ones i have seen before this one is by AIRADE it is made for the mulit port throttle bodies, meaning that it has 2 ports, rather than a single port, what do think now?
Old Aug 19, 2007 | 04:07 PM
mopowar's Avatar
mopowar
Default RE: before you say NO...
So its a newer and better paperweight.
Old Aug 19, 2007 | 05:13 PM
2500 mopar's Avatar
2500 mopar
your saying that this one is still no good even though it is multi port?
[IMG]local://upfiles/69821/49FFB2DE64744418BC31301364AA461D.jpg[/IMG]
[IMG]local://upfiles/69821/A880BF17310C4FADAEE03318308808FB.jpg[/IMG]
Old Aug 19, 2007 | 05:23 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
For a throttle body spacer to do anything on our engines it would have to be an intake manifold spacer.The tb spacers were made for Tb injected vehicle. The spacer allows more time for the air and fuel to mix to together and stirs up the air in fuel before it enters the combustion chamber. Our engines are multi point injection because you have 8 injectors spraying almost directly into the combustion chamber. All a tb spacer is going to do is look pretty and make it harder to get your air hat on and off.
Old Aug 19, 2007 | 05:26 PM
Fox Fader's Avatar
Fox Fader
2 ports, one port, 55 ports. The swirling action can't be held one it drops into the manifold.
Now, if you are set on getting one despite the reviews, testsand opinions, go ahead and let us know (honestly) how it works.
Old Aug 19, 2007 | 05:30 PM
2500 mopar's Avatar
2500 mopar
thanks guys and to fox fader no thanks pretty much everyone said teh same thing and i dont have 90 bucks to through out and the cost of running a dyno just to get a possible swirl action no thanks
THOUGHTS TAKEN IN CONSIDERATION.
Old Aug 19, 2007 | 05:59 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you want better performance, do what I did and read my engine threads.
Old Aug 19, 2007 | 06:42 PM
IndyRamMan's Avatar
IndyRamMan
the only throttle body spacer i would buy would be the $3,000 one made by kenne bell.
Old Aug 19, 2007 | 10:08 PM
cdusthockey's Avatar
cdusthockey
^^^ I like that
