Battery or Starter?
Old Aug 19, 2007 | 09:45 PM
RodMillenFan's Avatar
RodMillenFan
Default Battery or Starter?
I have a 1996 Ram 1500 with the 5.2 V8. Over the past month or so, it has been hard to start on random occasions. At first I thought it was a battery issue... it would seem to have a hard time turning over, so I'd try it a couple times. The first couple cranks would be barely more than a click and nothing... then VROOM, it started up like there wasn't a problem.
On a whim, I pulled the battery cables and cleaned off the terminals just to see if that was it. While I was there, I pulled the caps off just to make surethebattery hadn'tcracked and run itself dry (I've had that happen before). It looked fine, so I hooked it back up. Same problem.
Does this sound like a battery problem, or more likely a starter motor problem? I'm starting (no pun intended) to lean toward the starter. Thoughts?
Oh, and the other thing... once I hooked it back up, it started on the third crank... but then stalled. I cranked it again... started fine, then stalled. Third time, started to stall, so I revved to 2500RPM for a few seconds and let off the throttle. Started to stall again, so I revved it to 2500RPM for another few seconds. After a couple repeats it stayed running and hasn't had a problem.
I was wondering if unhooking the battery reset some ECU's or otherwise tweaked with the FI until it had a few seconds to run and such. Yeah, yeah... that's me just guessing. Thoughts on that problem?
Thanks in advance for y'all's help. I've owned this Dodge for about 5-6 years but I have only now joined this forum... hope to be more active soon.
RMF
Old Aug 19, 2007 | 09:53 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Battery or Starter?
Sounds like a battery issue to me. Have you put a voltmeter on the battery?
Old Aug 19, 2007 | 10:05 PM
mdelfunt's Avatar
mdelfunt
If I suspected the battery, place some jumper cables on it and see if its any different. If the starter is bad, jumping it off wouldn't make any difference.
Old Aug 20, 2007 | 01:39 AM
ryans590's Avatar
ryans590
my guess too would be the batt or a week alt not charging it fully, most shops and even parts stores will load test a batt to tell you how it is. they test to see how many amps they can draw off while maintaning voltage, you can still have good (12.4-12.6 volts) and have a bad bat if the bat tests out ok (whitch i dont think it will) have your alt output tested
