IDLE PROBLEM, PLEASE HELP!!!!!!!!!
Old Aug 20, 2007 | 05:34 PM
perronegro's Avatar
perronegro
Default IDLE PROBLEM, PLEASE HELP!!!!!!!!!
I have been having an iddling problem and I cant figure out what it is, here is what happens;
whenever the truck is in park iddling the rpms loop (go up than down, then back up and down ...........), the truck also seems very sluggish taking off and I cant hardly keep it at 70 MPH in the highway specially going up hill.
here is what I have done;
new plugs, distributor, rotor and wires
new IAC valve
new TPS
Cleaned the TB, and did a combustion chamber cleaning (with the mopar stuff they sell at the dealership)
here is what I have:
97 1500 dodge ram
automatic 4 spd
3.9 L
is a faulty PCM a good assumption?
Old Aug 21, 2007 | 04:20 PM
mojo's Avatar
mojo
Default RE: IDLE PROBLEM, PLEASE HELP!!!!!!!!!
No I don't think it is the PCM sounds like a vacuum leak. My guess intake manifold gasket. It is very popuar in the ram to have this issue. Check the rest of the lines but I think manifold gasket. With the truck running spray some throtle body cleaner on the vacuum lines and where the manifold meets the top of the head when the idle changes thats where the leak will be.
Old Aug 21, 2007 | 09:07 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: mojo
i have to agree withthat. i doubt its the PCM.
Old Aug 21, 2007 | 09:53 PM
WayneC's Avatar
WayneC
Sounds like you threw alot of money at this thing. And I concur...Vac Leak!
Old Aug 22, 2007 | 09:04 AM
perronegro's Avatar
perronegro
thanks, I will try that. it also it just came to me, all of this started happening after the tune up so I might have unhooked something. I will give that a shoot and let you all know how it goes.
Old Aug 22, 2007 | 11:59 AM
WayneC's Avatar
WayneC
Check your plug wire routing too, especially 4/8 and 5/7. They should not run parallel to each other and keep them far apart as possible. Still think its a vac leak though.
WC
Old Aug 22, 2007 | 01:06 PM
perronegro's Avatar
perronegro
well I have the 3.9 V6 and I tought for the routing on this one I only had to worry about the coil wire not being close to any of the other wires, is this correct?
Old Aug 22, 2007 | 01:49 PM
WayneC's Avatar
WayneC
Sorry, my bad. Thought we were talking about the 8.
Old Aug 22, 2007 | 02:56 PM
perronegro's Avatar
perronegro
no problem, I will make sure i check that to, when I replaced the wires, the coil wire i bought at the dealership was almost too short, so maybe I will get a longer coil wire and make sure is an 1" away from everything else.
Old Aug 22, 2007 | 03:26 PM
Socha_62's Avatar
Socha_62
Have you reset the PCM since this has happened? Unhook the battery for a few mins then reconnect it.
