left rear squeak
Old Aug 22, 2007 | 06:42 PM
tazman6789's Avatar
tazman6789
Default left rear squeak
jumped in my bed to get something today and noticed something on the left rear suspension is squeaking. but only when i jumped in the bed. think its just the leaf squeaking? or is the shock taken a turn for the worse?
Old Aug 22, 2007 | 06:56 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: left rear squeak
My Dad used to check the shocks by tugginga backcorner of thebed down and away from the center of the truck and then let go. If theA$$ end wiggles all over, the shocks are done and you're just riding on springs.
Not overly scientific, but it works if they're bad.
Old Aug 22, 2007 | 10:10 PM
dhvaughan's Avatar
dhvaughan
probably not shock. check leaf spring bushings and between-leaf spacers for squeak there's a tsb somewhere about the spacers... but give everything a good shot of wd40 or grease.
edit.. also check rubber bushing in shocks bolts (smear a little grease on it.)
Old Aug 23, 2007 | 04:45 AM
kayakman's Avatar
kayakman
I use grease. I think I posted it some time ago. But what I did was purchased a grease needle, put it on my grease gun. Pry the leafs apart a little bit and inject a good quality grease (marine type or something that won't wash away easily).
It will work for 3-6 months up here in the salt belt of eastern canada.
hope this is of some help.
Cheers Kayakman
