WELL ANOTHER PROBLEM!!!!!!!!!!!!
Old Aug 23, 2007 | 11:43 PM
3406pak's Avatar
3406pak
Default WELL ANOTHER PROBLEM!!!!!!!!!!!!
WHEN IT RAINS IT POURS. NOW ONTO ANOTHER PROBLEM I WAS DRIVING HOME FROM WORK THIS MORNING AND THE TRUCK STARTED TO LOOSE ALL POWER, AND HESTATING,BUCKING,POPPING AND BACKFIRING THRU THE THROTTLE BODY. I STOPPED AND SAT THERE FOR A COUPLE OF SECONDS AND THEN MATTED THE GAS PEDAL AND NO PROBLEMS. THEN ON THE WAY TO WORK TODAY IT ALL STARTED OVER AGAIN. WHAT THE #@&^!!!!!!!!
KEN
Old Aug 23, 2007 | 11:51 PM
shott8283's Avatar
shott8283
Default RE: WELL ANOTHER PROBLEM!!!!!!!!!!!!
please stop typing in all caps.... really not necessary
thanks
can codes? CEL?
Old Aug 23, 2007 | 11:59 PM
3406pak's Avatar
3406pak
will do!
Old Aug 24, 2007 | 12:05 AM
dishdude2k's Avatar
dishdude2k
c/e light on? if so what are the codes.. to me sounds like it could be a fuel pump.. check your pressure
Old Aug 24, 2007 | 01:01 AM
fcm42000's Avatar
fcm42000
have you touched the engine lately? moved wires? low on gas?anything?
Old Aug 26, 2007 | 04:25 PM
toolman_al's Avatar
toolman_al
3406 pak
did u ever figure out wat was happening to ur truck?
mine is doing the same thing bucking and backfireing thru the throttle body.
2000 dogde ram 1500 4x4 5.2 engine.115,00klm
I have replaced the iac,tps,coil,and have had a recent tuneup(plugs wires & cap)
when I start in the morning it starts good and runs fine till the first stop light(about 5 min)then it starts to act up if I feather the gas a little it will clear up and run great .also when I run it on the highway it runs great at all speeds.But if i stop somewhere to get a coffee and it sits for more that 5 minutes it does the same thing backfiring and bucking.no codes are shown on dash.anybody have any ideas cause this very frustrating?
Al
Old Aug 28, 2007 | 03:24 AM
3406pak's Avatar
3406pak
Yes I did figure it out I pulled the codes friday morning after a rough trip home from work. It gave me a code on the IAC and the O2 sensor. From what I figured out the iac was telling the pmc one thing and the O2 sensor was telling it another they were battling each other if this is possible? I changed the iac and the pre O2 sensor and cleared the codes and it runs perfect now. Thanks to everyone for there input. Hope this helps you out toolman_al!
ken
