adjusting the front bumper
Old Aug 24, 2007 | 05:19 PM
BadHab1t's Avatar
BadHab1t
Default adjusting the front bumper
does anyone know how to adjust my front bumper on my 99 ram sport the right side is pushed in just alilbit dummy me i pulled up to a cone in someones yard and tapped it lightly but there was a pole under it and well ya know ill never do that again.... so if anyone can help it would be appreciated....j
Old Aug 24, 2007 | 09:24 PM
dhvaughan's Avatar
dhvaughan
Default RE: adjusting the front bumper
very easy. there are several bolts and a few braces. if dirty, take it the car wash and clean with high pressure. then spray all the bolts with pb-blaster or wd-40 and let it soak a little and then spray em again. you'll need an 18mm (i think) deep socket and a pull bar or impact to break them loose. loosen everything up where you can move it around easily. i put a floor jack under the bumper to hold it where it wanted it, and then snugged it up, then re-adjusted a little more and then torqued it all back down. i adjusted both my front and rear and it looked a 1000 times better.
Old Aug 25, 2007 | 10:14 PM
BadHab1t's Avatar
BadHab1t
hey thanks for the help thats kinda what i was thinking but b4 i did something wrong i wanted to see what everyone would say.....
