Fabtech Vs. Skyjacker Vs. other lift kit brands???
Old Aug 27, 2007 | 10:21 PM
BigRedMiniRig's Avatar
BigRedMiniRig
Default Fabtech Vs. Skyjacker Vs. other lift kit brands???
which one should i get, or are there better companies to go with for a suspension lift, i want 35" tires on it tho so like a 4.5 to 6in lift is what i want.
i was leaning tward the fabtech 5.5"so i can get the optional dual front shocks. but i want your imput
thanks,
Fred
Old Aug 27, 2007 | 10:49 PM
padodgeram's Avatar
padodgeram
Default RE: Fabtech Vs. Skyjacker Vs. other lift kit brands???
i can only answer on what i got , thats a skyjacker 3" and i like it alot but as always want bigger 5" .. skyjacker only makes 3 , 5 , 7" susp. nice to know what you got as in year ? 1500, 2500 ? to fit 35" on a 1500 5 inch at least , unless u do what im gonna do a 3" body then 35 will fit great ..skyjacker has a dual shock set up and so does TGC ..you can also piece your lift toghter depends on your funds ...
Old Aug 27, 2007 | 10:52 PM
Sirhilton17's Avatar
Sirhilton17
I was going to get this one http://www.marketworks.com/storefron...mp;i=230024776
but decided on a littler lift... It looks nice.
Ive herd alot of good things about fabtech, but when I look I just look for the halfway good brands and get the one that doesnt have blocks or spacers to gain lift.. Id rather get lift from new springs and add a leafs.
Old Aug 27, 2007 | 11:45 PM
nhlbill's Avatar
nhlbill
Josh,
Exactly right, you want a kit that has a rear lift that does not include stacking blocks on top of the factory blocks. The Skyjacker 5" kit is a good kit. For the rear lift, SJ gives you a 4" add-a-leaf that levels the suspension and also aids in helping with axle wrap.I never had any issues with the SJ 5" kit other than height ( I wanted to go bigger).
