95 Ram 1500, Replace Cat?
Old Aug 27, 2007 | 11:36 PM
ViperJ's Avatar
ViperJ
Default 95 Ram 1500, Replace Cat?
So on saturday I bought my first a 95 Ram 1500, and I am thinking about replacing the cat because there seems to be a big lack in power from what I can tell in 3rd. It barley chirps coming off the line, I though I was just use to my STi (07 STI, built to 350+hp). Truck has 160,000+ miles and it looks to be the original cat, so is this worth replacing now, how do the stock ones hold up?
Old Aug 28, 2007 | 12:37 AM
motorbrreath's Avatar
motorbrreath
Default RE: 95 Ram 1500, Replace Cat?
go for it. maganaflow hi flow cat is what alot of people are runnin. welcome to the forum.
Old Aug 28, 2007 | 12:28 PM
82lowe36id's Avatar
82lowe36id
The stock cats are known to go bad. Usually before 100k, so I would count on it going bad soon. It may have been replaced under warranty once already.
Old Aug 30, 2007 | 11:09 AM
ccanales's Avatar
ccanales
If you have $250-$300 you don't mind spending in case that isn't the problem, go ahead.
Old Aug 30, 2007 | 01:19 PM
ViperJ's Avatar
ViperJ
Yeah cost is a factor, but I co-own a performance shop so I get everything at cost so its not as bad
Old Aug 30, 2007 | 01:44 PM
rtmorrisjr's Avatar
rtmorrisjr
ORIGINAL: ViperJ
well if thats the case....hook us up with some killer deals.
Old Aug 30, 2007 | 04:32 PM
Fox Fader's Avatar
Fox Fader
ORIGINAL: ViperJ
That's great! Which one and where. I want to do some volume business with you.
Old Aug 31, 2007 | 03:15 PM
PILOTGUY's Avatar
PILOTGUY
You canpick up a Magnaflow direct-fit cat from Summitracing for $160. Part number MPE-23285 This is the one I am going with.
Old Aug 31, 2007 | 04:36 PM
ViperJ's Avatar
ViperJ
Only problem is we aren't truck based...
All import sports car based with the main focus being Subaru WRX's and STi's. Also do EVo's, 350Z, 240's, there is a few truck things we can get but usally you have to do buyin's with the company (usually $2K or more) to start getting decent prices on products. Only reason I bought this truck is cause some "genies" decided to pull her car out and then stop in the middle of the road. So I T-boned her in my 07 STi which totaled my car. And this truck will give us something to put all the products in when we go to shows
