running rich...
Old Aug 28, 2007 | 05:45 PM
wrenchmonkey's Avatar
wrenchmonkey
Default running rich...
Hello all..[/align][/align]I have a 94 Ram with the 5.9. I have installed a 5.9 from a 96 Ram.[/align][/align]When I start the engine. I get black smoke like its running rich. Also running rough. [/align][/align]Is there something I have missed on this swap? Do I need to transfer the EGR over to the 96 engine even though it doesn't have one? [/align][/align]Any help would be much appreciated.[/align][/align]Thanks[/align]Tory[/align]
Old Aug 28, 2007 | 05:50 PM
motorbrreath's Avatar
motorbrreath
Default RE: running rich...
diesel or gas?
Old Aug 28, 2007 | 06:07 PM
WayneC's Avatar
WayneC
Just taking a stab...
...PCM?
Old Aug 29, 2007 | 01:14 AM
wrenchmonkey
Sorry, Its gas.
Old Aug 29, 2007 | 12:38 PM
mopowar's Avatar
mopowar
How much of it did you swap. 94 is obd1 and 96 is obd2, but it shouldn't matter if you reused all of your old peripherals, i.e injectors, map sensor, o2 sensor. If you used the tb off the 96, then you need to swap the map sensor. If you are using the intakemanifold from the 96, you may need to swap the iat and ect sensors. 94 used 39 psi fuel pressure with 24.5 lb/hr. injectors, while 96 used 49 psi with 23.2 injectors so if you are using the injectors off of the 96, then you need to put the ones off the 94 back in there.
Just a few ideas.
Old Aug 29, 2007 | 05:39 PM
wrenchmonkey
That is some great info mopower... Gonna get right on that. I did swap the injectors and the throtlebody but thats all. I'll check the iat and ect later tonight.[/align][/align]Should I also put the EGR on the new motor?[/align][/align]Thanks[/align]Tory[/align]
Old Aug 29, 2007 | 09:10 PM
wrenchmonkey
How about the crankshaft sensor? Is that the same? of do I need to change that?[/align][/align]Thanks.[/align]
Old Aug 30, 2007 | 04:56 PM
mopowar's Avatar
mopowar
I would think that the crankshaft sensor would be alright, but you could try it. Which distributor did you use? Did you set the fuel sync?
Old Aug 30, 2007 | 05:59 PM
wrenchmonkey
It is the 96 Distributor, This a problem? [/align][/align]Fuel sync has not been set...... nor do I know how. ha ha. I guess I would need a scan tool for that.[/align][/align]I am currently charging the battery. Soon I can give er another shot with the sensors changed out and see whats up....[/align]
Old Aug 31, 2007 | 09:40 AM
mopowar's Avatar
mopowar
I would definately swap at leastthe cam position sensor andcheck the fuel sync. Yes, you do need a Snap-on (or equivalent) scanner or a DRBIII (dealer). I would call around and try to find a shop w/ the Snap-on before going to the dealer.
