Brake Light and ABS Light
Old Aug 28, 2007 | 07:33 PM
Susan's Avatar
Susan
Default Brake Light and ABS Light
Hello,
I have a 99 Ram 1500 2WD and the ABS and Brake lights are on.
Had the speed sensor changed but lights are still lit. Any ideas?
1. Speedometer doesn't work till 25mph
2. Engine Revs when put in Park
3. Engine Revs when Started
4. Transmission not shifting properly
5. Doesn't seem to have very much power when stepping on the gas
All of this started with the ABS and Brake Light.
Sound familiar to anyone?
Thank you
Susan
Old Aug 28, 2007 | 08:19 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Brake Light and ABS Light
If you have a digital odometer, turn the key on (butdon't crank it over) off, on, off, onand the odometermight display a"P" then a series of numbers.
Post those numbers here and somebody will be able to help.
Old Aug 28, 2007 | 09:10 PM
Parts/Service's Avatar
Parts/Service
Which sensor did you have changed?
Old Aug 28, 2007 | 10:09 PM
Susan's Avatar
Susan
I'll try the key thing with my digital odometer.
The sensor I believe was on the transmission.
Thanks for the help
Old Aug 28, 2007 | 11:35 PM
Sinister's Avatar
Sinister
yeah there's another Speed sensor on the top of the Rear Differential that may need to be replaced., and that one is usually the one causing the problem you have explained.
Old Aug 28, 2007 | 11:46 PM
Susan's Avatar
Susan
Thank you very much....I'll check that out.
Susan
