Cruise control problem
Old Aug 28, 2007 | 09:31 PM
ScottsFJ40's Avatar
ScottsFJ40
Default Cruise control problem
I discovered a problem with my cruise control while driving my 1996 Ram 4x4 across country this weekend.
If I have the AC running and the cruise control set, everything seems to be working fine until I start to climb a steep grade. The cruise control seems to hold speed, but the AC switches from blowing out the dash and starts blowing out of the defrost wents. If I step on the brakes it returns to normal.
I am not sure if this is a vacuum problem, or what, and any advice on where to start looking would be great.
Old Aug 28, 2007 | 10:33 PM
WayneC's Avatar
WayneC
Default RE: Cruise control problem
So do you have an a/c problem or a cruise control problem?
Old Aug 28, 2007 | 11:02 PM
ScottsFJ40's Avatar
ScottsFJ40
I assume that it is a cruise control problem.
If I keep the cruise control turned off, the AC works just fine, regardless of how steep of a hill I am on.
Old Aug 28, 2007 | 11:14 PM
SnoPro Dodge's Avatar
SnoPro Dodge
Check your vacuum hoses under the hood. May have one cracked or loose. They are plastic tiny lines.Your loosing vacuum somewhere, which changes the door in the dash.
