front lifted..i think!
Old Aug 29, 2007 | 06:21 PM
mgt46fast's Avatar
mgt46fast
Default front lifted..i think!
i have an 01 ram 1500 5.9 4x4. It rolls on 285's and the front seems higher then the back. The entire underneath has been coated with rust proof and i cant tell if anything is aftermarket. How could i tell if it has spacers on the front or higher springs? If this is normal then what would be the easiest way to level the back out...lift the rear?
Old Aug 29, 2007 | 06:48 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: front lifted..i think!
Post a pic and we can tall you quickly if there is a spacer. Otherwise, on the top of the coil, does the coil spring rest in the spring tower, or is there a spacer between the tower and the top of the spring? If there is no spacer, it still could be a lifted coil spring, which will be harder to tell.
For the rear, best way to raise it up some is with an add-a-leaf (AAL).
