Weird Ticking Noise?
Old Aug 29, 2007 | 07:46 PM
Dodgeboy328's Avatar
Dodgeboy328
Default Weird Ticking Noise?
Hey guys! I haven't posted in a while and as usual I have a question. Lately I've noticed a fast ticking noise in the engine compartment. I have pretty much narrowed it down to the left value cover area and when I put my hand on the little hose that runs from the rear top of the cover to the intake I feel vibrations in harmony with the ticking. What is this and what does that little hose do anyway? It's not the only noise that my truck makes, but it makes me wonder. The area around the fan also makes a weird fluttering noise. Then my steering is starting to grind. That one really worries me. It's not power steering fluid because it's full. I think the pump might be going bad or I need new ball joints. I just hope it's not anything worse than that.
Old Aug 29, 2007 | 07:57 PM
Bouncer88's Avatar
Bouncer88
Default RE: Weird Ticking Noise?
I think you are thinking about the hose running from your PCV valve to your air intake?
Old Aug 29, 2007 | 08:44 PM
mcss8541's Avatar
mcss8541
It's probably your PCV valve. I change mine out at every oil change and it rattles for a few days then quiets down.
Old Aug 29, 2007 | 08:45 PM
Dodgeboy328
It's whatever runs from the value cover to the intake. There's a rubber grommit that it runs out of the cover from.
Old Aug 29, 2007 | 08:47 PM
Dodgeboy328
I've never replaced the PCV value and I bet the original owner never did either. How do you do it? Do you just pop it out and put another one in?
Old Aug 29, 2007 | 08:54 PM
mcss8541's Avatar
mcss8541
Yes sir takes about 60 seconds to replace. I change mine every oil change. Just pull the PCV hose off, pop it out , push the new one in an reconnect the hose. You will hear a rattling noise for awhile but it's the PCV. If you shke it prior to installing it you'll hear the same noise.
Old Aug 29, 2007 | 09:17 PM
Bouncer88's Avatar
Bouncer88
I am one of the younger users on this site and I am going to school to become an Auto Technician but I just wanted to say that when I try and help people on here and I end up being right it makes me feel soo good lol.
I know I need to grow up but really it does.
Old Aug 29, 2007 | 09:19 PM
mcss8541's Avatar
mcss8541
Roger That, 1 Actual!
Old Aug 29, 2007 | 10:14 PM
turkeyhunter1962's Avatar
turkeyhunter1962
Twice now I've had a fast ticking noise near my valve covers (once on each side) and have found both times that my header gasket was leaking. At first it is just a little ticking, then it becomes irritating.
Old Aug 30, 2007 | 06:21 PM
Dodgeboy328
I just went to Autozone.com and used their vehicle guide to check to see how much a new PCV value was and they say that it is on the right hand side of the engine. The ticking that I'm hearing is coming from the LEFT hand side of the motor. I didn't realize that there were hoses running from both value covers until just a second ago. Again, I'm talking about the hose running from a rubber grommit on the left value cover to the area of the intake below the throttle body. Sorry if there has been any confusion.
