air cleaner...
Old Aug 31, 2007 | 01:07 PM
Grumpy1988's Avatar
Grumpy1988
Default air cleaner...
ok guys and dolls,
this is what I did for the air cleaner, I have wondered how everyone thats done this has gotton the carb stud installed when the stud screw hole is about an inch off center?
so this is what I did...we will see how this works...any ideas and or comments?
[IMG]local://upfiles/70129/FA7FA634A4234DDD9762D74E013E3AEA.jpg[/IMG]
[IMG]local://upfiles/70129/E00A949C8CBA4C90ABB8568D404A9CEE.jpg[/IMG]
[IMG]local://upfiles/70129/105B81950EBE4B65A0E138E556B9DD26.jpg[/IMG]
Old Aug 31, 2007 | 02:53 PM
motorbrreath's Avatar
motorbrreath
Default RE: air cleaner...
looks pretty good. alot of poeple have adressed this problem by using a "s" bolt. i think the fastman talks about it. I just drilled a hole in my hair hat an inch closer and it fits perfect.
Old Aug 31, 2007 | 03:51 PM
Silver_Dodge's Avatar
Silver_Dodge
That bent bolt you made is what every one refers to as an s-bolt. You did the exact right thing. Pretty easy huh.
Old Aug 31, 2007 | 04:21 PM
Fox Fader's Avatar
Fox Fader
Yep, that's how everyone's been doing it.
I suggest a bigger air cleaner set up though.
Old Aug 31, 2007 | 04:37 PM
Silver_Dodge
Ya, no kidding. You got the room for it for sure. Use a taller filter.
Old Aug 31, 2007 | 05:47 PM
2500 mopar's Avatar
2500 mopar
who did you order form and did you have problems with raiseing or lowering? how much clearence is left?
THANKS
Old Aug 31, 2007 | 06:02 PM
Silver_Dodge
You must have a body lift because that amount of space above the filter is not normal.
Old Aug 31, 2007 | 06:39 PM
WayneC's Avatar
WayneC
Yeah, I wondered about that cavern in there myself. Although the diameter of the air cleaner is smaller than the 14" one, that's a HUGE space above the lid.
I'm jealous! Had to remove my TB just to reach my distributor!
Think I would circumcise that bolt tho.LOL
WC
Old Sep 1, 2007 | 02:36 AM
Grumpy1988's Avatar
Grumpy1988
I did cut down the size of the stud to match the top of the hat...I placed 2 inch body pucks everywhere...as in size...14 inch air cleaner or taller filter?
this is still experimental...I found it odd that there was a stud hole in the throttle boddy, there must be an aftermarket design for this? as for the heat issue, has anyone come across that yet?
Old Sep 1, 2007 | 10:07 AM
Quakindude's Avatar
Quakindude
Not dinging your work or anything, but I'm just not getting the reason behind folks wanting to use the old style air cleaner.
