Vacuum problem and Ground Wire Problem
Can someone take a picture of there vacuum line diagram for me. I have a 2001 2500 5.9 gas 4wd. it has to be around that year, i think no later than 98.Im havinga hard time fixing the lines. Also, when i was messing with the vacuum lines, i think somehow the ground wire that bolts to the back of the motor on the pass side shorted out. I know it shorted out because it melted all the plastic of and smoked real bad. could hooking the lines up wrong cause this, or what could. on the firewall, where the two ground wires bolt to, where does the other one go. Thanks
