View Poll Results: A poll
use regular mineral oil : if it's not broke / don't fix it
26.92%
use synthetic oil with no concerns about leaks
65.38%
wimp out and use a sythetic blend
7.69%
Voters: 26. You may not vote on this poll
Not Again : oil poll
Old Sep 2, 2007 | 06:39 PM
bill022572's Avatar
bill022572
Default Not Again : oil poll
Facts : if you had a 1500 with 5.2 and 120k miles and some sludge internally (recently replaced cyl heads and saw sludge around rockers and lifters) . There are no oil leaks anywhere and has used about 1/2 quart of oil in 2500 miles. History not known - just bought used approximatley2500 miles ago. Please : no groaning (I know this has been discussed many times) but I am trying to get all your opinions in 1 thread (oh : and help myself also). Question is : what would you do on your next oil change?
Old Sep 2, 2007 | 06:56 PM
padodgeram's Avatar
padodgeram
Default RE: Not Again : oil poll
flush the motor, and install what ever makes you sleep better at night.. i use dino oil ..
Old Sep 2, 2007 | 08:04 PM
pavement_hater's Avatar
pavement_hater
Synthetic doesn't really sludge. In fact it will do the opposite. It will flush away most of the sludge already built up inside an engine. Thats why you have the old tale of synthetics causing leaks. The leaks were already there, the sludge was just holding the oil in because the gaskets had already failed. I run nothing but synthetics. I have 1 vehicle with 64k that has had nothing but synthetics since 500 miles and another that was converted over at 81k when I bought it still having no troubles or leaks at 151k.
Old Sep 3, 2007 | 12:06 AM
nateblong's Avatar
nateblong
Put in the synthetic and run it for about 1,000 miles change it and marvel at how black the oil is. Now putnew synthetic oil back in it and put the miles on it. I would highly recommend 10w 40 (or 30 depending on where you liveMobile 1......, Royal Purple if you can afford it. I mean the stuff is great as I run it in my truck, jeep, daytona, motorcycle, lawnmower and all the other small engines that I own.
Old Sep 3, 2007 | 03:29 AM
Socha_62's Avatar
Socha_62
Just run Mobile 1 synthetic for upwards of 6k miles. The engine is apparently already well broke in. Syn causing leaks is an urban legend.
Theres no need to change oil after 1k miles unless its an actual new engine thats being broke in.
Old Sep 3, 2007 | 12:28 PM
nateblong's Avatar
nateblong
From my experience, switching over to synthetic oil on a vehicle that has over 50K will yield some very black oil after the first 1K. This of course is caused from the built up sludge in the engine from the mineral oil (conventional), that the synthetic oilcleans out.I personly change it because of all the sludge that gets cleaned out and blended into the new oil. I also prefer the oil to look like honey (as it should) and not like tar.
Old Sep 3, 2007 | 01:51 PM
aim4squirrels's Avatar
aim4squirrels
You could always run cheap dino oil with a quart of MMO for 1K and then switch to synthetic. That should be a little cheaper than cleaning it with syn.
Old Sep 3, 2007 | 07:04 PM
nateblong's Avatar
nateblong
Yah thats a good idea too, and I'm all about saving money.....
Old Sep 4, 2007 | 12:14 AM
steve05ram360's Avatar
steve05ram360
ORIGINAL: aim4squirrels
agreed, MMO is awesome stuff... stops noisey lifters too...
