O2 Simulators for my 97 SST
Old Sep 12, 2007 | 09:51 PM
onequikone's Avatar
onequikone
Default O2 Simulators for my 97 SST
Where can I get O2 sim(s?) for my 97 SST? Thanks
Old Sep 12, 2007 | 10:49 PM
steve05ram360's Avatar
steve05ram360
Default RE: O2 Simulators for my 97 SST
try www.fastman.com or www.krcperformance.com (not sure on that one)
welcome to df...
Old Sep 12, 2007 | 11:42 PM
ICEMAN_CH's Avatar
ICEMAN_CH
You could make one to.
Old Sep 13, 2007 | 05:41 AM
onequikone's Avatar
onequikone
Fastman.com isn't coming up for parts? How do I make one?
Old Sep 13, 2007 | 01:07 PM
ICEMAN_CH's Avatar
ICEMAN_CH
I'll get a post for the schematic. It's pretty easy to do all of the parts you need are at Radio Shack. Basically its just a flip flop timer. I was thinking about making them and selling them but noone seemed interested.
Here is a write up on how to build it. It should work in a dodge to but you might need a differnt voltatge. I'm not sure. You can change the voltage by changing the size of the resitor. Also depending on if you have FED emisions or CA Emision you might need to make two of them. You can tell if you have CA emissions by counting how many cats you have. Two cats = CA. nYou'll have an O2 sensor behind each one.
http://www.mkiv.com/techarticles/oxy...tor/index.html
You could also try this
http://www.s2ki.com/forums/index.php...p;hl=simulator
Old Sep 13, 2007 | 02:19 PM
mopowar's Avatar
mopowar
^ Awesome post. Those links were promptly bookmarked.
Old Sep 13, 2007 | 03:01 PM
ICEMAN_CH's Avatar
ICEMAN_CH
ORIGINAL: mopowar
I'm glad you found it useful. At first I didn't want to give it out. I was going to try and sell them, but I've gotten so much help of DF I figured I should share the wealth. I think that it's a good alternative to build them yourself since they cost close to 75$ each on the market and you can make them for something around 25$. When I install them in my truck I am going to install them next to theECM. That way I can leave the O2s installed and it will look like I haven't messed with any of the emissions system.
