No Start + Brake Problem
Old Sep 13, 2007 | 10:23 AM
blueram98's Avatar
blueram98
Default No Start + Brake Problem
I have a 1996 Ram 1500 SLT Lariat 5.9 4x4.
I was driving home yesterday and stopped to get gas. After I started the truck back up, the brake pedal went spongy, and as I drove offthe ABS and BRAKE lights came on. Once I got home I checked the brake fluid level, and it was low, so I brought it up to max. Here's where the no start problem began.
I hooked up my OBD II scanner to see if I got any codes relating to the brake problem. I hooked the scanner up before I started the truck; after turning the key, the lights came on, but it did not turn over. Each timeI turn the key again, nothing at all happens: no lights at all, no cranking, nothing.
It seems that I blew a fuse (at the very least), but I do not know why. Anyone have any suggestions? Also, where can I find a complete fuse diagram for my truck?
Thanks!
Old Sep 13, 2007 | 01:05 PM
blueram98's Avatar
blueram98
Default RE: No Start + Brake Problem UPDATE
I just looked at the fuses, and they all are OK. Battery is putting out 12.8V at rest.
I was able to get it started with a jump, but when I took my foot off of the gas, it stalled. Now I also have a puddle of brake fluid forming from a drip that is coming from above the gas tank.
Any ideas??
Old Sep 13, 2007 | 02:25 PM
WayneC's Avatar
WayneC
Electrically, if you can get it started and test the alternator output, see what you're getting. Alternator could have taken a dump on you. If you can't do both at the same time, take the alternator to a parts store and have it bench tested. Don't know why a code reader would have caused that.
Brakes: find and fix the leak. Bleed system. Brake line might be rusted through or corroded fitting.
