NEED FAST HELP!!!
Old Sep 16, 2007 | 08:15 PM
mikerados21's Avatar
mikerados21
Default NEED FAST HELP!!!
Okay so i got everything off my intake manifold except the fuel rails. And on the fuel rails there is a brass/gold looking connection! How do i get this brass/gold looking connection off?!?! Or do i just remove the fuel rails from the intake manifold.... THNX
http://www.putfile.com/pic.php?img=6625421The pic shows it off!
Old Sep 16, 2007 | 08:31 PM
Hemi Powered Ram's Avatar
Hemi Powered Ram
Default RE: NEED FAST HELP!!!
You'll need to go to the auto parts store and buy a A/C & Fuel Line Disconnect Tool Set
See attached pic
[IMG]local://upfiles/6925/26DD05037FD944A3B58044C10342F13D.gif[/IMG]
Old Sep 16, 2007 | 10:21 PM
dhvaughan's Avatar
dhvaughan
you'll need the 3/8 in size. its a 2 piece tool that wraps around the line. one side has a protrusion that sticks up inside the fitting and spreads the hidden fingers. then just kind of wiggle/twist it and it will come right off.
you can buy a nice expensive set for about $20, but the cheapy plastic $2-3-4 3/8 is all you need.
Old Sep 16, 2007 | 10:22 PM
rabbler's Avatar
rabbler
Or you can just remove the injector rail from the intake and pivot it out of the way.
