TIRES
Are you sure it should have 225s? Some of these trucks, like mine, came with 265s.
To answer your question, check out this site: http://www.discounttire.com/dtcs/infoTireMath.dos
This will tell you the differences that tire sizes have on your speedometer.
Will
Will
yes....its 2 wheel drive and when i bought it, it had 265-75-16, i just wanted to know how much this would throw the speedometer off because the other day my speedometer said i was goin around 58 and the officer said i was going 70.....just wondering??
Those radar guns have like a 6-7 mph fault, which you can use to your advantage if you choose to fight the ticket. Also make sure the cop has speed caliberation chart for the radar. half the timethe cop doesn't even show up and the other half the time they drop the points and you just have to pay the fine. Which is why you should alway fight your tickets.
But with the differnce in size... when you're going 60 you're probably going 70, that's more significan't the faster you go, less significan't the slower you go. So remember you're actually getting better gas mileage than you think you are, and your truck actually has more miles than the odometer says.Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
225/75-16 6.6in 14.6in 29.3in 92.0in 689 0.0%
265/75-16 7.8in 15.8in 31.6in 99.4in 637 8.1%
good thing you ask cause im running the 265/75r 16.. its 3 mph slower , now you ask how do i know ? well i drive past this thing that tells your mph so everytime i past it it showed 3 mph less then what i was doing...
thats funny.. my truck is a 4x4 and on the door jam it says its suppose to have 225/75/16's. Hmm........
Trending Topics
ORIGINAL: RamGuy318
