O2 Sensor
Old Sep 20, 2007 | 10:00 AM
pjcd701's Avatar
pjcd701
Default O2 Sensor
Can anyone tell me if they had problems with thier o2 sensors? The truck was running rough when first stated in the morning, (or when it sat for a while). This went on for a couple of weeks. When I shut it off and restarted the engine the truck ran fine. No codes came up. I took the truck in because of tranny problems and had the dealer look at it, they said the stalling was the sensors, I thought this was odd considering no codes came up, any input would be appreciated.
Old Sep 20, 2007 | 09:11 PM
WayneC's Avatar
WayneC
Default RE: O2 Sensor
Have the dealer show POSITIVE PROOF that it is the O2 sensor, i.e. scanner readings. NEVER take their word for anything!
Old Sep 20, 2007 | 09:12 PM
WayneC's Avatar
WayneC
Also, O2 sensors do nothing till warmed up so your starting problem is not likely due to it.
Old Sep 20, 2007 | 09:21 PM
aim4squirrels's Avatar
aim4squirrels
I'd guess your getting a littlemoisture somewhere, is it worse in the morning after you hit the dew point or on a rainy day?
Try dielectric grease on allspark plug wireconnections (at plugs, coil, and distributor) and check the distributor for cracks.
After the engine heats up it boils off the moisture and so a restart later isn't a problem.
Old Sep 21, 2007 | 09:57 PM
bluestraw's Avatar
bluestraw
I had an O2 code for about a week. Here's what turned off my engine light. I ran my gas empty, put in a can of Seafoam w/8 gallons of gas and my light was off 2 days later. It's been fine ever since and that was about a month and a half ago.
Could'nt hurt to try.
Old Sep 28, 2007 | 06:09 AM
Bigdodge98's Avatar
Bigdodge98
Good call on the seafoam it worked twice for me when i got the o2 sensor codes it cleaned em up and then no codes
Old Sep 29, 2007 | 12:15 AM
bluestraw's Avatar
bluestraw
I think this thread jinxed me. I had to run Seafoam again last night to get rid of the O2 code.
I wonder if I should remove the O2 & give it a good cleaning?
Old Sep 29, 2007 | 12:22 AM
steve05ram360's Avatar
steve05ram360
yes, cleaning the o2 is a good thing as long as its still serviceable... dead ones dont come back too easily. make sure you use CRC electronic components cleaner and be liberal with it, spray all of the exhaust stream openings real good, let it dry and then reinstall...
Old Oct 8, 2007 | 08:29 PM
soldierofanarchy21's Avatar
soldierofanarchy21
Default O2 Sensor and cat issues
engine light is on but goes off a couple days later then comes back on. it does this off and on for about a month now. the truck is a 2007 dodge ram 1500 w/8200 miles on it. dia says o2 and cat problems can that be right hardly any miles on it. MODS are 77 series k&n intake and Vortec exhuast single to dual. otherwise completely stock please help
Old Oct 9, 2007 | 02:10 AM
rabbler's Avatar
rabbler
Default RE: O2 Sensor and cat issues
an 07 with 8200 miles?
Why not just take it back to the dealer for warranty service?
