codes?
Old Sep 21, 2007 | 12:36 PM
azffighter's Avatar
azffighter
Default codes?
I'm getting this code that says too rich, too lean. Has anyone else seen this? What should I do or needs to be done?
Ken
Old Sep 21, 2007 | 01:11 PM
mopowar's Avatar
mopowar
Default RE: codes?
It helps if you include details about your truck in your post.
Options:
1) Put it on a scanner, find out what is wrong, and replace/fix as neccessary.
2) Start replacing parts at random until the problem goes away. If you are getting rich and lean codes and choose this option, I would start with the upstream o2 sensor and the map sensor
