oil gauge
Old Sep 23, 2007 | 08:38 PM
sabbath1994's Avatar
sabbath1994
Default oil gauge
alright this is retarded guys... my oil gauge.. once my truck gets hot the gauge jumps all around.. when the truck shifts the oil gauge goes down to about 20.. then just crusin it goes 40 down to 20 up to like 50 down to 0... its really weird... what u guys think it is..??
thanks
JEff
Old Sep 23, 2007 | 08:44 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: oil gauge
Have you checked your oil lately? Are you using too thin an oil?
Mine goes up when I step on it and down when I'm cruising or stopped but it isn't abrupt. It's going to move a little.
Also possible the sensor is going out, or the oil pump itself is going bad.
Old Sep 23, 2007 | 08:48 PM
sabbath1994
i just change the oil.... im using 10w 40.. my dad said the pvc valve or something was all clogged.. which doesnt make since to me because my dad doesnt know nothing about dodges...
Old Sep 23, 2007 | 09:16 PM
WayneC's Avatar
WayneC
[sm=funnypostabove.gif]
Old Sep 23, 2007 | 09:21 PM
aim4squirrels
PCV valve. pvc is plastic, but we get the point. It's on the passenger side of the engine in a 94 stuck in the valve cover in the back. A hose runs from it to the intake manifold. about a 3.99 fix at the auto parts store. Just be careful pulling the old one out becasue the old plastic tends tobecome brittle and break up.
Old Sep 23, 2007 | 09:23 PM
padodgeram's Avatar
padodgeram
wow , 420 to the rear ....check your blinker fluid..
Old Sep 23, 2007 | 09:57 PM
sabbath1994
ORIGINAL: padodgeram
nooo this is on my daily truck.. no my fast truck
Old Sep 23, 2007 | 09:58 PM
sabbath1994
but does that make since the pcv va;ve???
Old Sep 24, 2007 | 04:12 PM
heybuddy1901's Avatar
heybuddy1901
my guage does the same thing, even though i know my oil is fine, i think its the oil pressure sending unit.. its on the rear behind the TB
Old Sep 24, 2007 | 06:51 PM
hkspwrsche's Avatar
hkspwrsche
It was the sending unit on mine when that happened
