Are these differential covers any good?
ORIGINAL: dsertdog56
The 9.25 cover pictured is also avalible from Daytona products and couple of others. I believe the Mr Gasket cover is the same design. Its as tough as the OEM and about as thick.It is an import, and plating quality can vary slightly from piece to piece. Thin plating tends to pit quickly and then you get those littlered spots...so you need to keep it cleaned and waxed.
Dana 44 covers vary in thickness and there are a bunch of cheapthin ones out there that won't take a punch. The Spectre and Daytona ones are the thinnest. I believe JC Whitney sells the same one.
The best one I have seen and used is the one from Mopar performance. It is plated from an OEM thickness shell and that's a stout piece to begin with. But it's about fifty bucks retail...well it may be more now...
