E-brake cable slack?
Old Sep 25, 2007 | 08:15 PM
vulture1's Avatar
vulture1
Default E-brake cable slack?
Hello all,
While driving my '03 hemi ram quadcab offroad the other day I noticed that the E- brake light was on. Just to be sure at the next stop sign I pulled the release and it was supposedly already up all the way . I finally looked at it and when I pull the release handle and manually pull the pedal up, the back of the assembly touches the copper contact and the light shut off. Still with a light touch, the pedal glides down about 3/4 of an inch and it loses contact turning the light on. I looked and the cable has a little slack when the pedal is pulled all the way up, but the E-brakes work fine. Is there anything I can do to get the pedal to go all the way up again by just pulling the release? Thanks
Old Sep 25, 2007 | 08:38 PM
shott8283's Avatar
shott8283
Default RE: E-brake cable slack?
you may wanna post this in the 3rd gen section, them fellas may know more about your 03
Old Sep 25, 2007 | 09:12 PM
Works4Ford's Avatar
Works4Ford
I've got the same problem with my 01...gotta pulle the pedal up to turn the light off.
Old Sep 25, 2007 | 09:42 PM
vulture1's Avatar
vulture1
Thanks shott. I will post in gen 3 also.
