can a tire fit and still be wrong?
Old Sep 27, 2007 | 12:48 AM
97Ram2500's Avatar
97Ram2500
Default can a tire fit and still be wrong?
I picked up a set of SUV tires for my truck 97 ram 2500 5.9l V8 4x4 last winter. I don't know what the load range was or anything, but I bought them because they were like $10 a piece, they are 245/75/16 goodyear wranglers. Today I left my house and out of nowhere my steering started getting hard so I pulled off and the tire had split on the sidewall and was leaking so I took it back home and with in a minute it was completely flat. So my question is it possible that these tires were too light duty for the truck or should they have been ok?
Old Sep 27, 2007 | 01:25 AM
rabbler's Avatar
rabbler
Default RE: can a tire fit and still be wrong?
$10 a piece eh?
Maybe they arejust crappy worn out tires. Load range applies to how much weight the tires can carry. if your truck is not loaded you could use p metric passenger tires and still be fine
Old Sep 27, 2007 | 02:08 AM
spaz_22's Avatar
spaz_22
since your truck is a 3/4 ton you shouldn't really run anything less then a load range d, otherwise you run the risk of a blow out while hauling or towing something. as far as the sidewall.. they are probably just old tires...
Old Sep 27, 2007 | 07:20 AM
dhvaughan's Avatar
dhvaughan
might have also had a small leak and got low on pressure. that will put tremendous pressure on the sidewall.
Old Sep 27, 2007 | 09:44 AM
97Ram2500's Avatar
97Ram2500
I was using these up front since when I carried a load the pressure would be on the back tires which are load range E. The tires were dryrotted or anything like that, I don't drive the truck very much so it does sit for a while. I guess I'll just be looking for another cheap tire. Thanks.
