Sputtering when wet.
Old Sep 27, 2007 | 01:00 PM
frankenstein's Avatar
frankenstein
Default Sputtering when wet.
Hello, I own a 98 ram 1500 4x4 and when i run thru water it sputters for a a few minutes.
Can anyone help to give a solution ( Besides avoiding water puddles ) ?
Thank's
Old Sep 27, 2007 | 01:22 PM
Bouncer88's Avatar
Bouncer88
Default RE: Sputtering when wet.
Your distributor cap may be getting wet, check if it is, if it is spray it down with WD-40 that will make the water bead off of it, check your TPS sensor too for the same problem.
That should really only happen if going through deep water.
It could also be your crankshaft position sensor, if it gets wet it could lose track of the timing.
Not sure if those are your problems but I would check it out.
Old Sep 27, 2007 | 01:30 PM
Glideman88's Avatar
Glideman88
A cracked distributor cap is my guess. Had the same type of moisture issues in the past with both my truck and my folk's truck too.
Old Sep 27, 2007 | 01:31 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: Glideman88
Yeah if it is cracked it is definitely going to get some moisture in there.
Old Sep 27, 2007 | 02:57 PM
Crabman's Avatar
Crabman
It's your plug wires. Get a set of MSD wires and the problem will be solved. While your at it change your cap and rotor.
Old Sep 27, 2007 | 02:59 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: Crabman
It could be the wires but we don't know if it is definitely them, I think the only way the wires could be effected by the water is if there is a rip in the rubber, other wise it would most likely be a direct relation to the distributor.
Check your wires though it could be them.
Old Sep 27, 2007 | 03:54 PM
Silver_Dodge's Avatar
Silver_Dodge
Take it to a car wash, and spray it while it's running. When you hear it sputter like it does in puddles, then whatever you just sprayed is going to be the source of the problem.
Old Sep 29, 2007 | 08:16 PM
frankenstein
thank's I Will try.
Old Sep 30, 2007 | 07:23 AM
Crabman's Avatar
Crabman
Don't need to take it to a car wash. Get a spray bottle and mist the wires at night with the engine compartment bulb removed. You will see the arcing if you look real close. Probably back by the rear of the heads where the wire are bunched. Wires don't have to be cracked. The 8mm wires will allow arcing especially after they get old. That is why they have a special wire routing. 8.5mm MSD wires took care of my problem. My truck would miss on foggy or rainy mornings. After the change, nothing but smooooth.
Good Luck.
Old Sep 30, 2007 | 09:33 AM
timwag2001's Avatar
timwag2001
check your coil for loose wires and damage also... after time the coil tends to start to seperate and crack
