Rear Drum Brake Squeal
Old Sep 27, 2007 | 07:50 PM
suprchgrs's Avatar
suprchgrs
Default Rear Drum Brake Squeal
YES DRUMS! They squeal like a pig when applying firm pedal pressure while moving slow. What causes this? They were rebuilt with everything new about 200 miles ago.
Old Sep 27, 2007 | 07:52 PM
Bouncer88's Avatar
Bouncer88
Default RE: Rear Drum Brake Squeal
I had this problem on my dads sonoma, take off the drum and make sure that all the springs are in there nice and tight, my dads sonoma had a spring that was slightly rubbing against the drum causing a loud squeel.
Old Sep 27, 2007 | 07:54 PM
suprchgrs's Avatar
suprchgrs
makes sense, will check tomorrow, THANKS
Old Sep 27, 2007 | 08:06 PM
Bouncer88's Avatar
Bouncer88
ORIGINAL: suprchgrs
Not a problem.
Old Sep 28, 2007 | 03:23 PM
suprchgrs's Avatar
suprchgrs
Okay, here is what it was. The metal part of the brake shoe was making contact with the brake housing right at the top, above the cylinder, close to where the springs attach. A little sanding and EXTREMELY light grease spot took care of it.
Old Sep 28, 2007 | 03:24 PM
Bouncer88's Avatar
Bouncer88
Glad to see you found it.
Old Oct 2, 2007 | 01:49 AM
suprchgrs's Avatar
suprchgrs
thanks for the info
Old Oct 3, 2007 | 03:17 AM
suprchgrs's Avatar
suprchgrs
still working good
[IMG]local://upfiles/57058/10E99C48800145CF9DB447E7C5490235.jpg[/IMG]
