Transmission hesitating to shift
Old Sep 28, 2007 | 11:55 PM
master tech's Avatar
master tech
Site Moderator & Tech
Default RE: Transmission hesitating to shift
You are in the ball park. What maybe going on is the lip seal on the front drum and piston are causing you not to upshift until 45 to 50mph or until you let off the gas. Which means you may need to reseal the transmission. and the clutch disc and steels maybe okay.
