Help me ID Transfer case guts
Old Sep 30, 2007 | 08:45 PM
z28clone's Avatar
z28clone
Default Help me ID Transfer case guts
98, 1500, 5.9L, AT, 4x4, NP231D transfer case. TC clunks occassionally but worked in 4wd. I read alot old posts and decided to DIY it. Pulled off the case and parts in the pic are what I found loose in the case. Please id them for me. This is a buy/sell truck and I only want to replace the minimum for it to work again. I pushed my finger against the chain. it is sloppy i can get it to touch the inside of the case. I cant get the chain and gears out yet cuz I cant get the nut off the front of the TC where the front driveshaft is. Have had 150lbs with a air gun on it for 30min. Does only know of a website or company to get these replacement parts without charging an arm and a leg? Thanks.
Old Sep 30, 2007 | 08:49 PM
z28clone's Avatar
z28clone
Default RE: Help me ID Transfer case guts
pics didnt go the first time. hopefully this works
Old Sep 30, 2007 | 08:55 PM
aim4squirrels's Avatar
aim4squirrels
Pics still not there: make sure that they are under 500 kb total and you check the box to embed them in the into the post.
Old Sep 30, 2007 | 08:59 PM
z28clone's Avatar
z28clone
Ive tried 3times. pics are under 500kb. try this.
http://s212.photobucket.com/albums/cc31/z28clone/
Old Sep 30, 2007 | 10:22 PM
rabbler's Avatar
rabbler
I'm not sure about the plastic parts but the snap ring and the other 2 square blocks are part of the synchronizer assy. The synchronizer is required to allow you to shift into 4wd. It speeds up the front drive shaft gear to match the speed or the rear andallows you to shift without grinding. You'll have to disassemble the main shaft and look for other damage.
